mikeevans
Message 1 of 5 (310 Views)
Resource String Error exporting DWFX Civil3d R2014
310 Views, 4 Replies
09-05-2013 03:13 AM
I get a multiple error message dialogue "Cannot find resource string number XXXX in AeccPublishSVC 100 when exporting a DWFX file of drainage in Civil3d R2014 (I have R2013 open as well).
Anyone else getting this?
Mike Evans
Civil3D 2013 / 2014 British UK
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Product Support
Jason.Ferrelli
Message 2 of 5 (279 Views)
Re: Resource String Error exporting DWFX Civil3d R2014
09-06-2013 09:00 AM in reply to: mikeevans
Hi Mike,
I have created some pipe networks as well as pressure networks in a C3D 2014 drawing. I then tried to export this drawing to a DWFx while also having C3D 2013 opened. I did not receive any errors.
Would you be willing to upload your drawing(s) so I could test your drawing in my environment?
Jason Ferrelli
Product Support
Jason.Ferrelli
Message 3 of 5 (271 Views)
09-06-2013 10:02 AM in reply to: Jason.Ferrelli
Hi Mike,
This issue might be caused by having pay items assigned. If a pay item is assigned an object that does not meet it's requirements (Unit type etc), it will throw out these errors. Can you do me a favor and unassigned or detach the pay item list, then preform an export to DWFx and see if you still receive the string errors.
Jason Ferrelli
mikeevans
Message 4 of 5 (257 Views)
09-07-2013 09:04 AM in reply to: mikeevans
Will try Monday and let you know.
Mike Evans
mikeevans
Message 5 of 5 (244 Views)
09-09-2013 01:28 AM in reply to: mikeevans
I can confirm that this is due to pay item data being attached, detaching all pay item data from the objects does not produce this issue.
However, I have also tried attaching the pay item data and this also generates the errors. I will look through the information attached to the objects and see if I can find what items are causing the errors.
Mike Evans
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
