AutoCAD Civil 3D General Discussion
ajayanand
Message 1 of 5 (358 Views)
Report for Incremental Station Elevation Difference
358 Views, 4 Replies
03-20-2013 11:50 PM
I have more than 200 alignments of road network. The profile design are already done for this. I want to generate Incremental Station Elevation Difference report for all the alignments. For this I have to select each alignment, its respective profile & generate the report for it. As am having more than 200 Alignments I will have to repeat the process 200 times. Is there any way to make the process easier like generating report for all the alignments at once?
Active Member
bnmurali
Message 2 of 5 (284 Views)
Re: Report for Incremental Station Elevation Difference
06-20-2013 11:17 PM in reply to: ajayanand
under list of alignment select all the alignment and then create report it will show all the report in one single file
ajayanand
Message 3 of 5 (277 Views)
06-21-2013 02:48 AM in reply to: ajayanand
You maybe talking about Incremental stationing report. This is different from Incremental Station Elevation Difference report.
ajayanand
Message 4 of 5 (269 Views)
06-21-2013 07:24 AM in reply to: ajayanand
We cannot select all Alignments at time for generating Incremental Station Elevation Difference Report. This is because the surface is also to be selected along with the alignment and the surface will be different for each alignment.
*Expert Elite*
Jay_B
Message 5 of 5 (261 Views)
06-21-2013 07:44 AM in reply to: ajayanand
You are correct, the Incremental Station Elevation Difference Report will only report one alignment at a time and compare a FG profile to a EG profile to calculate the difference.
AFAIK all  reports would need to be created individually.
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
