Civil 3D Forum
Report for Incremental Station Elevation Difference
4 REPLIES 4
1229 Views, 4 Replies
I have more than 200 alignments of road network. The profile design are already done for this. I want to generate Incremental Station Elevation Difference report for all the alignments. For this I have to select each alignment, its respective profile & generate the report for it. As am having more than 200 Alignments I will have to repeat the process 200 times. Is there any way to make the process easier like generating report for all the alignments at once?
4 REPLIES 4
under list of alignment select all the alignment and then create report it will show all the report in one single file
You maybe talking about Incremental stationing report. This is different from Incremental Station Elevation Difference report.
We cannot select all Alignments at time for generating Incremental Station Elevation Difference Report. This is because the surface is also to be selected along with the alignment and the surface will be different for each alignment.
Jay_B
You are correct, the Incremental Station Elevation Difference Report will only report one alignment at a time and compare a FG profile to a EG profile to calculate the difference.
AFAIK all  reports would need to be created individually.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Rail Community
