Hi guys
I want to be able to repath a data shortcut I have on my drawing to a file thats on my C: drive, how do I do this? Its just for this one drawing I want to do it with, so the Data Shortcuts Editor is no good to me.
Cheers
Solved by jmatthei. Go to Solution.
First delete the old .LNK file, then browse to your .DWG in Explorer, right click on it, and now you have 2 choices:
1] CREATE SHORTCUT (in place)
2] SEND TO => DESKTOP
I found an approach that's a bit ridiculous, but seems to work.
1) Be sure nobody else is using your old source or destination file for anything--get them to close out.
2) Temporarily rename your old source file to something else. Like add a "temp" after it or something. This will break your existing links.
3) Open your destination file. You will get a broken link error box.
4) Go through the broken link boxes to point to your new source file. Save.
5) Rename your old source file back to its original name, to unbreak the link to all the other drawings.
I haven't found a way to do this without breaking the links--which makes this procedure pretty annoying for anybody else on the project team, but it does seem to work.
My terminology:
Old Source File: Where the original surface lives - the one you don't want to reference anymore.
New Source File: Where the desired surface lives - the one you do want to reference.
Destination File: The file you're working in with the data shortcuts to the surface files.
Jeremy
Hi Jeremy, thats actually what I ended up doing, hehe. Not the prettiest, but it did the job 🙂
