It appears, and I may be wrong, that the survey database does not have the ability to renumber EXISTING survey points.
I know of the "AP" command (and toggle in the settings), but I believe that's for user created database points.
Here's an example: I have a database with points (1-1000). I have another XML file (say with 500 points) numbered 1-500. I want to import these points into my existing database, but without over writing points 1-1000. Instead, shouldn't I be able to renumber the 500 points to 1001-1500?
I am not seeing this ability. I know of several work arounds, but, it seems that the survey database should allow for renumbering (instead of overwriting by default).
Thanks for your help,
pw
