Civil 3D Forum
Renumber Tags (menu item -- PLURAL). Required to be one at a time?
2 REPLIES 2
doni49
465 Views, 2 Replies
C3D 2012
Select ONE SINGLE tag (Line & Curve label tag).  "Labels - General Segment Label" ribbon tab appears with a menu item "Renumber Tags".
But if I select more than one tag, this item is grayed out/disabled.
1) Is there someway to perform the command on a group of tags?  I removed one tag from the middle and want to decrement the rest of them by number.
2) If you're going to require this be done 1-at-a-time, wouldn't it make sense for this to be called "Renumber Tag"?
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
2 REPLIES 2
wfberry
in reply to: doni49
Yes, but if I remember correctly you do not have to start the routine over.
Bill
doni49
in reply to: wfberry
It was still a PITA.  I had 50 tags that needed renumbered.  When I saw "Renumber Tags", I thought it would do them all.
Don Ireland
Rail Community
