I will rename several structures but it seems not to work. In the Civil 2009 it worked, but in 2011 something goes wrong.
Menu: Pipes/Utilities/Rename nw parts
Select first: I do
Select next: f ex 10 structures away.
Then the dialogbox appears, but it says just 1 structure selected.
Ok: just the last selected structure will be renamed.
if I cancel the command, the first selected structure is still selected, but I cant unselect it by Esc.
I have to select it again and then it can be unselected by Esc.
It seems to do anything with the zoom-function. If I just select a few structures without zooming the renaming works, nearly every time, but not a larger amount of structures.
If I use the ribbon-menu, I can't select many structures.
I appreciate some help.
