I have uninstalled an Add-on (Holebase SI) and unloded the menu via MENULOAD but the menu keeps appearing after restarting Civil 3D - how can I permanently remove this?
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by neilyj666. Go to Solution.
Can you delete it in the CUI? If that doesn't work there may be a registry entry that's causing that.
Allen
Allen Jessup
CAD Manager - Designer
I would suggest renaming the CUIX to .ZIP and look in it for an additional CUI file created from your uninstalled program. If it's there, remove it.
