Civil 3D Forum
Removing Circle on Cross Section at Alignment Crossing in C3D 2009
13 REPLIES 13
Message 1 of 14
9526 Views, 13 Replies
I have generated cross sections along an alignment for an existing surface. For some reason, the cross sections are generated with a small magenta circle appearing at the alignment crossing (offset of 0). I can't figure out how to turn these off.
Anyone have any ideas?
Thanks in advance!
13 REPLIES 13
Message 2 of 14
JessieQuilatan
Can you attach your dwg file for examination?
Michael Merlino
Civil Engineering Technician / "CAD Manager"
SAN JOSE, CA, USA
Message 3 of 14
in reply to: JessieQuilatan
Unfortunately, the drawing is much too large to attach. I have attached a picture. The magenta circle in the middle is what I'm referring to. It seems to be connected to the grid, not the section itself (when I freeze the section layer, the circle is still present).
Thanks again for the help!
Message 4 of 14
wfberry
Have you looked at your Code Set Style?
(Toolspace -> Settings -> General -> Code Set Styles -> [you need to know the style you are using.]
Bill
Message 5 of 14
I checked out the Code Set Styles but did not see anything about a circle in the grid.
The thing that is really getting to me is that the surfaces, alignments, profiles, and sample lines all have the same style for both the existing and finished grades. Yet this is only occuring on the existing grade sample line in the cross section view.
FYI the magenta circle looks similar to that found at Station 0+00 on stationing lines (and both of my stationing lines use the same style).
Message 6 of 14
Found it!
For those who are having a similar issue, here is what I did:
Go to your alignment line and right click -> edit alignment style
Under the Markers tab, edit the Station Reference Point style
Under the Display tab, change the View Direction to Section
You will see a Component Type called "Marker" -- Disable the visibility
Bam!
Thanks again for the help.
Message 7 of 14
Aurpul
I had this exact problem after, I attempted to try your soultion but it did not work in my case. I ended up just deleting the cross sections and recreating it.
Message 8 of 14
Pointdump
E,
Nice! Be sure to mark your own post as a "Solution" so that others can benefit.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 9 of 14
Aurpul
in reply to: Pointdump
Well I would like too but it came back. I made a change to the cross section style to show my annotation at the bottom and it came back, So close but no cigar.
Message 10 of 14
Rickquin1965
in reply to: Aurpul
"Go to your alignment line and right click -> edit alignment style
Under the Markers tab, edit the Station Reference Point style" (here you'll need to select a style to edit, my default was "none", so I had no luck at first, then I chose basic and then was able to disable the display )
"Under the Display tab, change the View Direction to Section" (I left mine at plan)
"You will see a Component Type called "Marker" -- Disable the visibility"
Message 11 of 14
PFHeller
in reply to: Aurpul
Deleting it and recreating it worked for me.
Message 12 of 14
technetic
This is quite tricky, but thanks to you I solved it right away.
Message 13 of 14
KirkNoonan
These can come in handy sometimes. They can be displayed for every alignment - eg. row lines, etc. I usually set the Basic marker style to something that doesn't diplay. You can turn it off in the section view properties. See below
Message 14 of 14
ddcNYWLL
in reply to: KirkNoonan
☝️This is the solution! Thanks @KirkNoonan
Rail Community
