Is there any rehab subassembly that will do (Overlay and Mill and Widen and MatchSlope) similar to CaltransOverlayMatchSlope1 plus Milling on first part.Any tips on how to build one?
No, they are currently defective. They do not create the Mill and Level shapes correctly.
We should all be refunded proportionately for this current lack of software capability due to the product defects within these subassemblies.
As @fcernst stated, the rehab subassemblies do not calculate milling and leveling correctly. If you are in need of those quantities, then you're out of luck. If you just need to get elevations and cross sections, then you can use the built-in subassemblies for that.
There are problems, though, with the built-in subassemblies like feature lines just not connecting up in the middle of a region.
OK, now I see the confusion. For some reason this post came up like it was a recent post and I was responding. I see now that it was created over two years ago. What version fixed it? Because the last time I tried in 2015 the rehabs were still doing it incorrectly. And there's still a problem with OverlayMillAndLevel2 where the crown feature line will sometimes just not connect between sections even in the middle of a region. It was reported to development and still no fix as of now.
