When referencing utility networks into other drawing files is there a way to set styles and layers for the network so it is imported correctly with the same styles and layers as the orginla drawing?
Solved by Jay_B. Go to Solution.
Is it more than making sure the same part list a styles are in both files? I have to try
Your Name
Your Name
yea, I have the same style and part list in each drawing. When you reference it in it asks for what layer you want pipes and structures on but doesnt ask for what style you want to use. I cant find what is dictating the style that it is inserted on.
thanks!! I see how its set up, within the parts list there is a default style setting for each pipe type and size that it defaults to when referenced.
