Hi-
I found several posts on the same subject but no solutions. I keep getting error messages in Panorama that a "Reference surface "blah blah" is not found in the reference drawing" or the same message but for alignment rather than surface. One post said to bring the surface or alignment in the drawing I'm opening. That didn't help. I tried removing the data shortcut and creating a new one. That didn't work. Any suggestions? It's really slowing down the opening of my drawings.
Thanks so much!
Meredith
C3D 2014 up to date
Windows 7
I get this all the time in Plan Production sheets with Surfaces which are associated to a Pipe Network in it's source dwg.
I realize you mentioned Alignments but with out knowing more re: your workflow etc. it's hard to follow where C3D might be looking for the Alignments your seeing in Panorama.
What these are these alignments are associated to on your project may provide the needed clue to correct the problem.
For example a PN can also have an Alignment Name: Reference in Pipe Network Properties of source dwg and unable to find it in production sheet.
Don't really recall seeing this message for Alignments here but see it a lot for missing surface references.
Can you post your dwg files (the active one and the one that's being referenced)?
What version is this?
Don Ireland
Engineering Design Technician
You can also suppress this warning by over-riding the surface with <none> when you create the data shortcut.
John Mayo
Can you post your dwg files (the active one and the one that's being referenced)? I etransmitted the file but it is too big to add as an attachment. I posted it to a share site. If anyone wants to look at it, send me your email address to mchamberlain@mragta.com and I'll send you the link to the share site.
What version is this? C3D 2014 SP 1
I attached a screenshot of the error messages on Panorama.
Thanks so much!
Meredith
Has anyone found a resolution to this yet? I have a file with a surface and pipe network in it. I have a sheet file with that other fie XREF'd in to it. When I open my sheet file it says the surface is not found in the referenced drawing. I even deleted the surface (which is a merged surface) and re-created it. When I open my sheet file it states the same message but with the new surface name, so that didn't fix it either. I'm at about 10 minutes per file to open.
Michael
