If you have points at the locations of the signs, the Points > Station Offset to Points report would work well.
Mike
I'm not sure you can get a station referance to a point. But you can get a sign symbol into a drainage structure. create a structure style for each sign, create a pipe network of only structures. now youll have a dynamic sign table from the network
Joe Bouza
Humphrey,
I stumbled upon this Third-Party Software that seems to do what you want:
https://www.youtube.com/watch?v=PUFaE0pK4TI
Dave
Dave Stoll
Las Vegas, Nevada
I like this idea Joe. Pipe networks can be used outside of the box for a lot of things. Think about inlet filters/protection with a hidden pipe style next time you do an SESC plan. Fully dynamic block locations. Lots of fun things.
John Mayo
Joe Bouza
Joe,
"Thankfully I didn't use the word 'all'..."
Are you still smartin'? I'm so glad I resisted stepping into that one.
As for Pipes, I've only done Tutorials, so I don't know much about them. But I've set your idea up on a shelf inside my brain and might use it someday.
Dave
Dave Stoll
Las Vegas, Nevada
Been Licking my wounds all weekend, Dave 🙂
I'm all ...um ah... mostly better now 🙂
Joe Bouza
You can add a User Defined Property Class to points.
Settings>Points>User Defined Property Class
Create the station property. After creating this, you will see that property at the bottom of the Properties Palette when you select a point. Pretty sure it shows up in the prospector and panorama too, but I never use those for points.
This is a non-dynamic manual property, but it can be added to a table. How often would you move signs anyways?
AND you can always make the point label be the sign block. Win Win.
Bill,
"...you can always make the point label be the sign block."
That opens up some interesting possibilities! Another idea to place on a shelf in my mind.
Dave
Dave Stoll
Las Vegas, Nevada
