Solved by ericcollins6932. Go to Solution.
Assuming you want a simple profile and know the distances between your setups, reduce your data and make up arbritary xy positions for each setup into a text file
x,y,z
0,0,105.57
0,30,106.63
0,55,103.21
Bring these in and make a profile from them. Or try the following:
From the Home tab, Create Design Panel, Profile drop-down, Create Profile from File
