Civil 3D Forum
Redefine Surface
9 REPLIES 9
Message 1 of 10
neilyj666
702 Views, 9 Replies
Redefine Surface
I have an existing ground built from contours but the client has now fshortcutsound a real topographical survey.
I now need to build the existing ground using the new info.
What is the best easy to do this so that all existing data shortcuts are maintained? I thought that erasing the surface build information and then rebuilding with the new
info would be the best way to - am I correct?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
9 REPLIES 9
Message 2 of 10
neilyj666
in reply to: neilyj666
Fshortcutsound should read found- not used to this swype keyboard on my galaxy
Message 3 of 10
Jeff_M
That's what I would do.
Message 4 of 10
neilyj666
Thanks Jeff - is it a bad idea to delete the surface, create a new one of the same name and then build ??
Message 5 of 10
Jeff_M
Yes, I would avoid deleting it and recreating. Removing the data operations is essentially doing the same thing without resetting the Surface object's handle. The only reason I would ever delete the surface to start over, would be if there were corruptions of some sort going on.
Message 6 of 10
joshuamodglin
Just to elaborate, data shortcuts use the entity handle to identify the object which is being shared. This is a unique id for the object and stays even when the surface is renamed.
However if the entity handle is not found, by default the shortcut will look for an object of the same type with the same name in the same drawing.
Thus, you CAN delete and create a new surface with the same name but I think I would prefer to keep the surface I know is good and works and just 'redefine'.
Hope this helps
Josh Modglin
Advanced Technologies Solutions Logo
Message 7 of 10
neilyj666
Thanks - I thought this process of incorporating the new data was going to be a bit painful but it seems like it should be quite straightforward (fingers crossed as I'm up against a deadline for it....!!!)
Message 8 of 10
neilyj666
Just tried removing definitions and rebuilding and seems to be working well. Smiley Happy will complete on Monday.
I'm sure that previously (in C3D 2011) I'd deleted the surface and created a new one of the same name but this ultimately caused major crashes and problems
Message 9 of 10
BrianHailey
in reply to: joshuamodglin
In the data shortcut editor (found on the windows start menu I believe) you can change your data shortcuts from looking at the handle of the object to lookint to the name of the object instead. So, if you NEED to delete the object, you can repath the shortcuts to a new object with the same name if necessary.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 10 of 10
neilyj666
in reply to: BrianHailey
Thanks Brian - I'd forgotten about the shortcut editor
Rail Community
