Civil 3D Forum
Recover Drawing
4 REPLIES 4
281 Views, 4 Replies
Recover Drawing
Greetings all,
I have a drawing, created a few months ago in 2012, that I can no longer seem to access. I run recover, audit, purge, audit, purge, etc. I've seen this before, but am not sure there is a solution. I run audit, it creates a layer called $Audit-BadLayer and I then repeat. I cannot access the file, as upon zooming/scrolling, C3D 2012 locks up. This is an isolated incident, as I havent had this problem with any other drawing.
Has anyone found a solution to this?
4 REPLIES 4
AllenJessup
Not specifically. I'd suggest saving the recovered drawing and inserting it in to a new file created from your template.
Allen
Allen Jessup
CAD Manager - Designer
tcorey
If you are able to open the drawing, try using Wblock to write some objects out to a different drawing file. Did it work and create a drawing that behaves? Do more objects or, if you're feeling cocky, all objects.
When you purged, did you use the command line version, -purge, or the version that calls a dialog? Use the command line version and be sure you purge Regapps.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Joe-Bouza
Can you get a shadow copy off the server?
Joe Bouza
Lisa_Pohlmeyer
Can you post the drawing file?
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Rail Community
