Civil 3D Forum
Recent documents list
53 REPLIES 53
Message 1 of 54
neilyj666
12850 Views, 53 Replies
My recent documents list (C3D 2011) is full of dst files - how can I reset it??
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
53 REPLIES 53
Message 2 of 54
AlmasSuljevic
in reply to: neilyj666
Hi neily,
Can you elaborate where do yuo see that list/ Is it within Civil 3D or from Start?
In Civil 3D Options menu>Open and Save tab there is  place where you can set number of recently opened files. If you just want to remove DST files you would have to exit out of Civil 3D, locate the DST files and delete them. While still in Civil 3D see where the location of the DST files are.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 3 of 54
AllenJessup
I'd look in C:\Users\<UserName>\AppData\Roaming\Autodesk\C3D 2011\enu\Recent and see if there were Links to the DST files that could be eliminated.
Allen
Allen Jessup
CAD Manager - Designer
Message 4 of 54
Jeff_M
in reply to: AlmasSuljevic
@AlmasSuljevic wrote:
Hi neily,
Almas, this is crazy! Seriously, you are suggesting to delete DST files? Why would anyone want to delete their SheetSet files? Yes, the recently used files fills with theh DST files which has friven everyone nuts for years. And there's no easy way to remove them (even deleting the DST files will not rmove them from the recent files list). What's worse, is that they don't roll out even after not accessing a dst for months, it will still show up as recently used, leaving just 3 or 4 spots for DWG files.
This is a screen capture from my C3D2010 install. The first 4 MRU files listed are files that no longer exist...and I deleted them about 2 years ago, shortly after installing 2010. Many of the other files listed haven't been accessed in nearly a year. My MRU setting is 25, note that 23 of these are used by DST's, leaving just 2 for dwg's.
Jimmy Bergmark has posted some ideas on this, but I haven't tried these on the newer versions....http://blog.jtbworld.com/2008/09/clear-sticky-sheet-sets-from-recent.html
Jeff_M, also a frequent Swamper
Message 5 of 54
Sinc
In my experience, the Recent Docs list has been broken since the 2009 release (the 2008 release was the last one where it worked correctly).
I've seen various tips on the web for how to get rid of those .DST files, but I haven't found anything that really works.  The list of recent.DST files seems to be stored in multiple places...  I think there's something that re-adds DST files to the Recent Docs list from the Sheet Set Manager, or something like that.  I never did spend enough time on it to figure out what was going on.
It's definitely been frustrating, having something that should be as simple as the Recent Docs list be broken for multiple releases...  I haven't checked 2012 yet to see if anything has been fixed.
Sinc
Message 6 of 54
Joe-Bouza
in reply to: Jeff_M
How bazaar is that... I just came to the board because I encountered the very same thing
Joe Bouza
Message 7 of 54
AlmasSuljevic
in reply to: Jeff_M
I have seen many cases were customers wanted to remove DST files which do came back if Civil 3D is still running. So my suggestion how to remove them was in that light. I was not even sure if that is the intent. Obviously this is not the issue neilyj is having. Sorry if I confused soem of you. Smiley Sad
I found that you may manually remove the item by right-clicking on it. It is manual process but it works. See image:
Almas Suljevic
Autodesk, Inc.
Message 8 of 54
neilyj666
I'm getting exactly what Jeff_M is getting.
I have recently been creating/testing sheet sets so I have a lot of temporary/test dst files that could be deleted without any worry. I'll take a look at the link too
Message 9 of 54
Sinc
Almas, that looks like a new feature in 2012.
Sinc
Message 10 of 54
Jeff_M
in reply to: Sinc
No, that looks like Window's Start menu....not the file list in C3D.
Message 11 of 54
AllenJessup
in reply to: Sinc
No. It works in 2011. Be aware that Almas is showing it being deleted from the start menu. Not from inside Civil 3D. Allen
Allen Jessup
Message 12 of 54
Sinc
in reply to: Sinc
Oh wait, you're in the Windows Start menu...
I can remove the DST files from there, but it has no effect on the Recent Docs list inside of C3D.  The DST files are still in there.
And as I just discovered, DST files might magically reappear in that list for no apparent reason....  I deleted the DST files from the Start menu for C3D 2011, but the next time I started C3D, the DST files appeared in the list again for no apparent reason.
Sinc
Message 13 of 54
AlmasSuljevic
in reply to: Sinc
Let me check around to see where that list may be residing. Stay tuned.
Almas Suljevic
Autodesk, Inc.
Message 14 of 54
AllenJessup
in reply to: Sinc
They're probably nestled in a couple of places in the registry also. Allen
Allen Jessup
Message 15 of 54
Sinc
OK, the DST files get re-added to the list when the SSM is opened.  If the SSM is docked to the side and set to auto-hide, you'll see the DST files reappear in the Windows Startup list during C3D's startup.  Otherwise, they reappear the first time you open the SSM.
Sinc
Message 16 of 54
AllenJessup
in reply to: AllenJessup
Someplace line this: HKEY_USERS\S-1-5-21-2108289806-3803732536-250371831-1001\Software\Autodesk\AutoCAD\R18.1\ACAD-9000:409\Recent File List
Allen Jessup
Message 17 of 54
AlmasSuljevic
Hi all,
Talking to the members of AutoCAD team I am finding that this issue is reported to the development as a core AutoCAD issue. No information when or will it be fixed any time soon. BTW, The recent file list is stored in registry: HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.1\ACAD-9000:409\Recent File List.
The best thing to do here is to pin recent drawings so that they do show up. Hopefully this will push DST files down the list.
Almas Suljevic
Autodesk, Inc.
Message 18 of 54
neilyj666
Nice bug.....could quickly make the recent documents list pretty pointless...!?!?!?!
Message 19 of 54
_Hathaway
So, has anyone found a solution for this.  This just started happening to me and it's a tad annoying.
Message 20 of 54
neilyj666
in reply to: _Hathaway
Very irritating bug but no solution - here's hoping for Civil 3D 2013...........
Rail Community
