chadporter
Message 1 of 6 (256 Views)
Re-inserting alignment labels
256 Views, 5 Replies
04-29-2009 02:38 PM
I accidentally deleted the major and minor station labels along my alignment. Is there a way to re-insert them?
*C3D_RickGraham
Message 2 of 6 (256 Views)
Re: Re-inserting alignment labels
04-29-2009 02:48 PM in reply to: chadporter
version??
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
*C3D_RickGraham
Message 3 of 6 (256 Views)
04-29-2009 02:55 PM in reply to: chadporter
But in general, right-click on the alignment line
and select Edit Alignment Labels (or something similar - I'm using 2010 so the
verbiage might be different). In the dialog box, select Major Stations, pick
your style. Click Add. select Minor Stations, pick your style. Click
Add.
done.
I
chadporter
Message 4 of 6 (256 Views)
04-29-2009 03:15 PM in reply to: chadporter
Thanks a ton. I am using 2009 and it worked great.
Active Member
dleyland
Message 5 of 6 (158 Views)
12-06-2011 07:08 AM in reply to: *C3D_RickGraham
I am using 2011 and this does not work. Any ideas?
New Member
nburlingame
Message 6 of 6 (109 Views)
03-29-2013 01:12 PM in reply to: dleyland
I am using the 2013 version.  Click on alignment, right click and select "Edit Alignment Labels..."  If you have a label set already defined (named and saved in your template,) click on "Import label set..." and choose your saved set.  Otherwise, choose a type and style, and click the add button for each one.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
