Civil 3D Forum
Re-inserting alignment labels
5 REPLIES 5
599 Views, 5 Replies
I accidentally deleted the major and minor station labels along my alignment. Is there a way to re-insert them?
5 REPLIES 5
version??
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
But in general, right-click on the alignment line
and select Edit Alignment Labels (or something similar - I'm using 2010 so the
verbiage might be different). In the dialog box, select Major Stations, pick
your style. Click Add. select Minor Stations, pick your style. Click
Add.
done.
I
Thanks a ton. I am using 2009 and it worked great.
dleyland
I am using 2011 and this does not work. Any ideas?
nburlingame
in reply to: dleyland
I am using the 2013 version.  Click on alignment, right click and select "Edit Alignment Labels..."  If you have a label set already defined (named and saved in your template,) click on "Import label set..." and choose your saved set.  Otherwise, choose a type and style, and click the add button for each one.
Rail Community
