AutoCAD Civil 3D General
Valued Contributor
Message 1 of 5 (106 Views)
Raising pipe inverts
106 Views, 4 Replies
01-07-2014 08:48 AM
I'm drawing existing SD pipes and trying to put in rim and inverts of the existing structures. Sometimes it won't let me raise an invert to where it really is. It only let's me raise it so far. It may be a rule but it doesn't seem to be a rule I can change. What can I do?
*Pro
Message 2 of 5 (103 Views)
Re: Raising pipe inverts
01-07-2014 08:50 AM in reply to: jnjhuz
when this happens to us it is a problem with the height of the cover that is part of the structure.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Valued Contributor
Message 3 of 5 (101 Views)
01-07-2014 08:54 AM in reply to: dgordon
What can I do? I can 't change the ground.
Distinguished Contributor
Message 4 of 5 (94 Views)
01-07-2014 09:14 AM in reply to: jnjhuz
The issue could be that whatever part you are using won't work in your situation, and you need to select a different part.  For example, a typical manhole with a cone section can only be used to a point, at which point you need to switch to a flat-top.  Perhaps the part you are using has a restriction that is affecting the invert?
Andy
Andy Reese
C3D 2014, SP1
Dell Precision T3500, Windows 7 64-bit
Valued Contributor
Message 5 of 5 (91 Views)
01-07-2014 09:17 AM in reply to: areese9779
OK. I'll try another part. Thanks.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
