Active Contributor
karen.woodward
Message 1 of 2 (127 Views)
Radial Acceleration input in Civil 3d
127 Views, 1 Replies
10-10-2012 04:33 AM
Hi there,
I need to change the radial acceleration value in Civil3d when designing for superelevated bends to shorten the tranistion of a track. I can calculate the transition manually but is there a way i can input this data in the design criteria while carrying out the alignment geometry design in Civil 3d.
Your help is much appreciated.
Product Support
AlmasSuljevic
Message 2 of 2 (83 Views)
Re: Radial Acceleration input in Civil 3d
10-12-2012 05:39 AM in reply to: karen.woodward
Hi Karen,
The criteria tables can be edited by editing XML file, but eventually you would have to edit it yourself as I don't belive radial acceleration values are in any available XML files. So if you can either edit values or find some custom XML file that somebody already created.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
