I am putting together ROW markers using a process found on the Being Civil blog. The Marker setup shows on the Assemblies fine, I go through the corridor section editor and I can see the marker at the proper location for the ROW. The ROW marker will not show up on the section views, Not sure if I missed a step but everything seems to work up to the point of putting them on the section views. Any thoughts? I am using AutoCAD Civil 3D 2012. Thanks!
If you can see it in the secito neditor that generally means you're doing the right thing. Sounds to me that the appropriate code set style has not been applied to your actual section views.
