Member
unathinonkasa
Message 1 of 3 (155 Views)
RIGHT EDGE- CENTRE EDGE AND LEFT EDGE levels of vertical alignment
155 Views, 2 Replies
03-24-2014 01:49 AM
I have a problem. The left and right edges on my profile are the same as the centreline levels.
Joe-Bouza
Message 2 of 3 (112 Views)
Re: RIGHT EDGE- CENTRE EDGE AND LEFT EDGE levels of vertical alignment
03-24-2014 02:07 PM in reply to: unathinonkasa
I'l assume you data band is picking up a surface profile and when you build your corridor surface you may have omitted the top links and/or overhang correction?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
tyronebk
Message 3 of 3 (105 Views)
03-24-2014 03:13 PM in reply to: unathinonkasa
You aren't giving us much to go on to help you. My suggestion is to make sure you have assigned the correct profile to the correct band in the profile view properties. It currently looks like all 4 elevation bands are assigned to the existing ground profile -- make sure they are all assigned to their respective profiles.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
