Jay_B
Message 11 of 19 (436 Views)
Re: Quick profile with Civil 3D 2012
03-27-2013 10:00 AM in reply to: boris.yordanov11
There's a recent thread showing a very similar Data Band to what you've shown Here
Take a look at the attached captions.
We don''t show quite that much information in our Data Bands.
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
boris.yordanov11
Message 12 of 19 (421 Views)
03-29-2013 03:56 AM in reply to: troma
It did and i managed to make one. The thing is that some of the data in the band needs to be about the road itself(lengths,slopes and what-not). As far as i know i need to draw a line(the road) on top of the profile and then i need to adjust the settings so that the line is regarded as a road in the profile. I don't know if you understood anything because i didn't understand it myself.
Right now i have the data about the surface that i need, but i need to add the road somehow.
troma
Message 13 of 19 (404 Views)
04-01-2013 05:23 AM in reply to: boris.yordanov11
No, I don't understand all of it, but I suggest that you draw a profile "By Layout".  You can choose to trace over the surface profile or not.  The layout profile will give you the options to draw however you want, and display the data in the data bands.
Credit where credit is due! Give kudos or accept as solution whenever you can.
boris.yordanov11
Message 14 of 19 (384 Views)
04-14-2013 03:57 AM in reply to: troma
troma you've been very helpful the profile layout did work out eventually It was one of those things where it's very simple once you understand how to do it.
A couple of things came up though:
1.I used the Vertical geometry data band, because i need to display the length of each section and the degree of it's slope (in per mils). It immediately displayed the length but i haven't figured out how to do the degree.
2.Curvature geometry - it does it's job well - it shows the information i need but not the correct one. I tried playing with the settings(by selecting the layout profiles) but they are all grayed out - it won't let me change anything, check 11.jpg in the attached files.
3.When i use the Elevation and stations it displays the wrong information:
3.1 check image 12.jpg - this is one of the points of the profile and you can see it has an elevation of 880.042 but you can see in 13.jpg that the values in the data band are completely different. I haven't gotten my head around on how to fix it.
3.2 Question about the stations in 13.jpg - i'm not sure in what kind of dimension or form the information is represented, but i need it to be in km or meters. If i draw a line that's 1 km long it corresponds to the station 32+80.84 in the data band
troma
Message 15 of 19 (367 Views)
04-15-2013 07:06 AM in reply to: boris.yordanov11
1 & 2, not sure. Hopefully someone who uses geometry data bands can jump in & help.
3. Take Note: 1000/3280.84 = 0.3048. You are dealing with feet to metres conversion. Did you start out your work in a metric template? It is vital to start as you mean to finish; in either feet or metres. The template has various settings for units that should all be set in the template before you begin.
boris.yordanov11
Message 16 of 19 (345 Views)
04-21-2013 11:47 PM in reply to: troma
I agree with you, however at no point in the creation i had an option to chose or edit units and i'm using Civil Metric not Imperial. So i'll have to work on that. Thanks for the tip though
troma
Message 17 of 19 (334 Views)
04-22-2013 09:44 AM in reply to: boris.yordanov11
So you say you started with the right template, but obviously something has crept in somewhere.  Did you copy any styles in from a differnent drawing?
There are a few places to set units, but the most important one for C3D (AFAIK) is in:
Toolspace > Settings > Master View > right-click on the drawing name > Edit Drawing Settings > Units and Zone.
boris.yordanov11
Message 18 of 19 (322 Views)
04-23-2013 08:44 AM in reply to: boris.yordanov11
Check the attached image i think everything is as it should be.
By the way - i haven't used any templates or copied anything - i've done everything,myself, from scratch.
troma
Message 19 of 19 (318 Views)
04-23-2013 09:23 AM in reply to: boris.yordanov11
Yep, it looks good to me too. Did you also check in the UNITS command? If that doesn't solve it I don't know where else to look. Perhaps you can post the drawing and someone can look at it.
BTW, for anyone else reading along, we're still waiting for help with the geometry data bands too!
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
