AutoCAD Civil 3D General
Message 1 of 4 (92 Views)
Quick Select Points
92 Views, 3 Replies
01-24-2014 09:35 AM
I am trying to use Quick Select and select a group of point by either point style or point label style.
I am using the =Equals operator and typing in the correct name, but nothing happens.
Anyone else having this issue?
Mike Porter
www.ppeng.com
Civil3D 2014 SP1
Win 7 Professional - 64-bit
HP Z400
Xeon W3550 @ 3.07Ghz
24GB of RAM
Nvidia GeForce GTX 760
Jeff_M
Message 2 of 4 (84 Views)
Re: Quick Select Points
01-24-2014 09:52 AM in reply to: mikepo
Yep, QSelect has never worked using Styles. Which is one reason we added the BuildPointSelectionSet command to the Sincpac-C3D.
Valued Mentor
Message 3 of 4 (75 Views)
01-24-2014 10:43 AM in reply to: mikepo
A workaound I see would be to put all the points needing selection into a point group.
Eric Collins, P.Tech.(Eng.)
Win 7 Enterprise SP1 64 bit
Intel i7 3770 @ 3.40 GHz
16 GB RAM
Civil 3D 2012 SP2
Message 4 of 4 (64 Views)
01-24-2014 11:00 AM in reply to: ericcollins6932
Yes, that was my ultimate goal.
The issue was the points I needed were mixed in among other points.
So I had a point label style assigned to the points I needed, and a different point label style assigned to the points I didn't need and was trying to do a quick select and delete the uneeded points.
Thus finding out that choosing the point style or point label style in quick select wasn't working.
I got it done the hard way, but was curious if others had the same issue with quick select.
Thanks for the input.
Mike Porter
www.ppeng.com
Civil3D 2014 SP1
HP Z400
24GB of RAM
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
