Civil 3D Forum
Quick Select Points
3 REPLIES 3
CADmgrMike
1252 Views, 3 Replies
Quick Select Points
I am trying to use Quick Select and select a group of point by either point style or point label style.
I am using the =Equals operator and typing in the correct name, but nothing happens.
Anyone else having this issue?
Mike Porter
https://provostandpritchard.com/
3 REPLIES 3
Jeff_M
in reply to: CADmgrMike
Yep, QSelect has never worked using Styles. Which is one reason we added the BuildPointSelectionSet command to the Sincpac-C3D.
A workaound I see would be to put all the points needing selection into a point group.
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
Yes, that was my ultimate goal.
The issue was the points I needed were mixed in among other points.
So I had a point label style assigned to the points I needed, and a different point label style assigned to the points I didn't need and was trying to do a quick select and delete the uneeded points.
Thus finding out that choosing the point style or point label style in quick select wasn't working.
I got it done the hard way, but was curious if others had the same issue with quick select.
Thanks for the input.
Mike Porter
Rail Community
