Neilw
Message 1 of 13 (248 Views)
Quantity summary across multiple dwgs
248 Views, 12 Replies
11-14-2012 01:37 PM
I'm looking for suggestions on how to compile quantities for cost estimating when the data is scattered across multiple files. Aside from generating quantities for each drawing in seperate .csv files etc., is there some way to pull the data from all the drawings at once into a single summary file?
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Joe-Bouza
Message 2 of 13 (243 Views)
Re: Quantity summary across multiple dwgs
11-14-2012 01:41 PM in reply to: Neilw
You talking QTO or simple acad?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Neilw
Message 3 of 13 (242 Views)
11-14-2012 01:57 PM in reply to: Joe-Bouza
Ideally it would be with one tool but I don't think QTO can extract quantites from XREF's. I know we can use MAP report queries to extract data to .csv files but it won't work on C3D objects. There is the data extraction tool but I expect it has the same limitations.
I'm wondering if Infrastructure suite has tools for this or can we do it through DWF's?
WIN 7 64 PRO
RADEON 6450, 1 GB
Joe-Bouza
Message 4 of 13 (228 Views)
11-14-2012 02:58 PM in reply to: Neilw
correct! only primitive. But I think you may be mistaken about the QTO across files? I haven;t looked at it in a while
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Neilw
Message 5 of 13 (223 Views)
11-14-2012 03:22 PM in reply to: Joe-Bouza
QTO doesn't seem to recognize anything in XREF's Joe.
WIN 7 64 PRO
RADEON 6450, 1 GB
BrianHailey
Message 6 of 13 (211 Views)
11-14-2012 03:58 PM in reply to: Neilw
Ah, young padawan, you must try again. QTO does recognize through an xref but you must ensure the pay item file is the same in both files:
http://screencast.com/t/zUiHt7NjMUw6
Neilw
Message 7 of 13 (204 Views)
11-14-2012 05:10 PM in reply to: BrianHailey
Excellent. Now, how can one determine what pay item files were used on the drawings?
WIN 7 64 PRO
RADEON 6450, 1 GB
Joe-Bouza
Message 8 of 13 (195 Views)
11-14-2012 06:02 PM in reply to: Neilw
If I had to guess more than likely there either isn't or its different. And how come I didn't get the check :smileywink:
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Neilw
Message 9 of 13 (191 Views)
11-14-2012 06:19 PM in reply to: Joe-Bouza
I guess you deserve some credit for thinking it was possible so here's a check (Kudo):smileywink:
WIN 7 64 PRO
RADEON 6450, 1 GB
Neilw
Message 10 of 13 (182 Views)
11-14-2012 09:31 PM in reply to: BrianHailey
I can't find anything in the help system that states QTO works on XREF's. How did you learn about it Brian?
Another challenge: can we limit the extraction to the extents of clipped XREF's? I can't make that work.
WIN 7 64 PRO
RADEON 6450, 1 GB
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
