Civil 3D Forum
Quantity summary across multiple dwgs
12 REPLIES 12
Message 1 of 13
Neilw_05
439 Views, 12 Replies
I'm looking for suggestions on how to compile quantities for cost estimating when the data is scattered across multiple files. Aside from generating quantities for each drawing in seperate .csv files etc., is there some way to pull the data from all the drawings at once into a single summary file?
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
12 REPLIES 12
Message 2 of 13
Joe-Bouza
in reply to: Neilw_05
You talking QTO or simple acad?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 3 of 13
Neilw_05
in reply to: Joe-Bouza
Ideally it would be with one tool but I don't think QTO can extract quantites from XREF's. I know we can use MAP report queries to extract data to .csv files but it won't work on C3D objects. There is the data extraction tool but I expect it has the same limitations.
I'm wondering if Infrastructure suite has tools for this or can we do it through DWF's?
WIN 10 64 PRO
Message 4 of 13
Joe-Bouza
correct! only primitive. But I think you may be mistaken about the QTO across files? I haven;t looked at it in a while
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 5 of 13
Neilw_05
QTO doesn't seem to recognize anything in XREF's Joe.
WIN 10 64 PRO
Message 6 of 13
BrianHailey
Ah, young padawan, you must try again. QTO does recognize through an xref but you must ensure the pay item file is the same in both files:
http://screencast.com/t/zUiHt7NjMUw6
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 7 of 13
Neilw_05
in reply to: BrianHailey
Excellent. Now, how can one determine what pay item files were used on the drawings?
WIN 10 64 PRO
Message 8 of 13
Joe-Bouza
If I had to guess more than likely there either isn't or its different. And how come I didn't get the check Smiley Wink
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 9 of 13
Neilw_05
I guess you deserve some credit for thinking it was possible so here's a check (Kudo):smileywink:
WIN 10 64 PRO
Message 10 of 13
Neilw_05
I can't find anything in the help system that states QTO works on XREF's. How did you learn about it Brian?
Another challenge: can we limit the extraction to the extents of clipped XREF's? I can't make that work.
WIN 10 64 PRO
Message 11 of 13
BrianHailey
I don't remember where I learned it. Most likely one of my students asked if it could be done and my response was, "I don't know, let's try!"
GEI Consultants
My Civil 3D Blog
Message 12 of 13
owenmull
Don't let Brian fool you, I taught him.
-Owen
Windows 7 x 64 bit
Civil 3D 2017
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
Message 13 of 13
Joe-Bouza
in reply to: owenmull
Secrets are so hard to keep Smiley Very Happy
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Rail Community
