Hi There,
When I calculated cut & fill volume using quantity takeoff criteria I got cut volume : 214.13 and fill volume 966.13
But when i calculated surface volume of eg and corridor by volume method (by comparing) I got cut volume cut 973 and fill 214. It is almost other way around
I have attached the cad drawing and screen shot of quantity criteria and volume comparsion.
But If i select eg - Below , datum corri surf - Above for CUT
eg - Above , datum corri surf - Below for CUT , I am getting the answer closer to volume comparsion method. But it does not make sense.
Please help How should I do
I really appreciate your help
John
Hi There,
But If i select eg - Below , datum corri surf - Above for FILL
John
