AutoCAD Civil 3D General
Active Contributor
Jon0001
Message 1 of 6 (226 Views)
QTO Units in 3d not 2d
226 Views, 5 Replies
02-22-2013 03:52 PM
Hey
SO i have a problem i have my csv built and it works except it is giving me my pipe lengths in 3d not 2d i have used LNFT no spaces after or before  and all i get is 3d length.
Any help would be great.
Active Contributor
Message 2 of 6 (192 Views)
Re: QTO Units in 3d not 2d
02-23-2013 10:19 AM in reply to: Jon0001
Try connecting your CSV points with Line instead of polyline or 3dpoly. That will give you a true 2D length.
Erika
AUTOCAD Civil 3D 2013
Windows 7
Processor: Intel (R) Xeon (R) CPU W3565 @ 3.20GHz
Installed Memory (RAM): 12.0GB
System Type: 64-bit
Erika
Message 3 of 6 (182 Views)
02-23-2013 07:33 PM in reply to: Jon0001
Jon,
What version are you using? I have our 2013 version setup to use the CSV file with our pipe network and it reports the 2D length of pipe. I'm not sure how I could make it even give the 3D length?
Are you assigning the pay item in the parts list or manually assigning them to the pipe?
Bruce Klug
AutoCAD Expert Elite
AutoCAD Civil 3D 2014 Certified Professional
C3D 2014 (SP1)
Win 7 Pro, 64-bit
BrianHailey
Message 4 of 6 (161 Views)
02-24-2013 12:48 PM in reply to: klugb
I'm seeing the same thing as Jon (I'm assuming that is the original posters name, if it's not I apologize). I have a pipe that is 500' long (in plan view) with a change in elevation of 50' (just for testing purposes). When I run the QTO tools, it gives me a length of 502.49' (which is the 3D length).
Bruce, are you adding the pay item through the parts list or adding it to the pipe through the QTO tools?
Active Contributor
Jon0001
Message 5 of 6 (141 Views)
02-25-2013 07:14 AM in reply to: BrianHailey
I have tried to mannualy add and through the part list i still get 3d lengths.
Message 6 of 6 (137 Views)
02-25-2013 07:27 AM in reply to: Jon0001
I must have changed my default when setting up the template.
See image.
Bruce Klug
C3D 2014 (SP1)
Win 7 Pro, 64-bit
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
