I'm doing some cleanup and updating on one of our client's c3d templates. After much simplification, I'm still left with a few straggling "C-ANNO..., C-ROAD..." layers. I've gone through every style 3 or 4 times now and see no trace of styles that contain these layers. My ambient layers are all set to 0.
Any suggestions on how to locate these unpurgable layers?
Sincpac's CivilStyleProperties command will locate them for you within styles or use the merge layer command LAYMRG.
Just merge the unwanted layers to zero or appropriate layer.
Assuming you meant Object Layers?
Yes the Object Layers tab not the Ambient Settings tab.
If a layer other than 0 is specified in the layer column it should not delete.
John Mayo
Yeah, I've used laymrg in the past but it didn't affect the civil 3d styles.
i'll try it again.
and yes, i meant object layers not ambient layers.
