Civil 3D Forum
Publishing Issues
1 REPLY 1
frankp23
295 Views, 1 Reply
Publishing Issues
Has anyone had this problem ?
I am going to print a very large document (47 pages). I have the page setups set to print to a pdf writer. We use the cute pdf writer program. Never had any probelms with it before. If I print to the pdf writer one sheet at a time. Works great. If I publish, all of the layers turn on in each sheet in the pdf.
Troy Moore, PE
Windows Vista
Civil 2012
Troy Moore
Civil3D 2014
Windows 7 Pro, 64 bit
Intel Xeon E31225 @ 3.40Ghz
16 GB RAM
Tags (2)
1 REPLY 1
AlmasSuljevic
in reply to: frankp23
Hi Troy,
Not sure about cure PDF, but I find that DWG to PDF.pc3 (installed by default) works OK for me. Few things I do remember, thought, is that PUBLISHCOLLATE system variable controls the plottings of individual sheets or multiple sheets. But most likely, the issue you have is taht your memeory cannot handle all sheets. I would suggest trying to plot in smaller groups.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Rail Community
