When I try to plot a set of files to one PDF, all my plots offset to the right. This never happens if I Publish to Plotter through Sheetset Mgr. or use the plot dialog in C3D. Only Publish to PDF through Sheet Set Mgr. Does anyone know of a setting I should check?
Did you try selecting new window in Plot dialog (what to plot) instead of extents? Then see if program gets better area. Try print preview to see. Also do you get the same bahavior if you use DWG to PDF.pc3?
Sheet set manager want you to use Layout, not extents or window. Also, does the review of you pagesetup show correct?
Joe Bouza
