Civil 3D Forum
Publish to PDF Sheetset Mgr - .DWG to .PDF Plots offset
2 REPLIES 2
pserpas
968 Views, 2 Replies
When I try to plot a set of files to one PDF, all my plots offset to the right.  This never happens if I Publish to Plotter through Sheetset Mgr. or use the plot dialog in C3D.  Only Publish to PDF through Sheet Set Mgr.  Does anyone know of a setting I should check?
Windows 7 x 64
Nvidia GeForce GTS 450
8 GB Ram
Intel Core i5-2310 @ 2.90 GHz
v. F.107.0.0 AutoCAD Civil 3D 2012 SP1
2 REPLIES 2
AlmasSuljevic
in reply to: pserpas
Did you try selecting new window in Plot dialog (what to plot) instead of extents? Then see if program gets better area. Try print preview to see. Also do you get the same bahavior if you use DWG to PDF.pc3?
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Joe-Bouza
Sheet set manager want you to use Layout, not extents or window. Also, does the review of you pagesetup show correct?
Your Name
Your Name
Rail Community
