I have a file with about 20 layout tabs that I want to publish to a multi-sheet PDF. Here is what I do:
1. Select all tabs
2. Right click -> Publish Selected Layouts
3. Select all sheets and chose my page setup which is set to plot to a full-size PDF (PDF995 Driver)
4. In publish options, set File Type: Multi-Sheet file, Naming: Prompt for name, Layer info: Don't include
When I hit Publish, CAD starts to publish, and after about 5-10 minutes it asks for a file name. However, the resulting PDF has only one sheet. Then it asks for another file name, resulting in the next sheet, and so forth until it publishes about 5 of the 20 sheets I selected as single-file PDF's.
The interesting point is, when I do the above steps identically with the page setup that plots to a half-size PDF (PDF995 Driver) set to the exact same settings, CAD successfully publishes my 20-page PDF.
I have tried setting publishcollate to both 1 and 0, but this does not fix the problem.
Any other ideas??
