AutoCAD Civil 3D General
Active Contributor
nathan07
Message 1 of 4 (241 Views)
Proposed profile and existing surface not showing in Profile
241 Views, 3 Replies
06-17-2013 08:50 AM
I have a profile showing proposed storm sewer, existing sanitary, rock surface, existing surface, and proposed profile. Today for some reason the proposed profile and labels, and the existing surface are not showing on the profile and I'm not sure what has changed or how to get them back.
Jay_B
Message 2 of 4 (232 Views)
Re: Proposed profile and existing surface not showing in Profile
06-17-2013 09:11 AM in reply to: nathan07
Is this a Profile in a plan and profile sheet and are data references being used?
If so see the solution to This post.
Jay
C3D 2014 SP1
Win 7 Professional 64 Bit
Active Contributor
nathan07
Message 3 of 4 (229 Views)
06-17-2013 09:21 AM in reply to: Jay_B
Yes Data sources are being used for the existing surface but the proposed
profile was drawn on the profile when I first created it. And the profile is
just in model space. The red line is the rock surface but there should be
the existing surface and the proposed profile above it.
IVS2112
Message 4 of 4 (187 Views)
06-18-2013 09:50 PM in reply to: nathan07
Dont worry,  If you 've the bak. up file of the drawing, problem wil be solved.
waht's you version number??
any version.... you may goto the file option, select the DRAWING UTILITIES, then select the RECOVERY option.
then automaticallyy your old drawing file will be come back.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
