Habib_Nespak
Message 1 of 3 (168 Views)
Proposed and Existing Elevation on a single Point
168 Views, 2 Replies
02-06-2014 02:24 AM
dears
i want to show a two elevation like ground level and proposed level at same point and want to find the difference of elevation.
please help me in this regards
Habib Ahmed
Joe-Bouza
Message 2 of 3 (147 Views)
Re: Proposed and Existing Elevation on a single Point
02-06-2014 04:31 AM in reply to: Habib_Nespak
Use a reference component in your label style to pick up the second surface
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
wfberry
Message 3 of 3 (138 Views)
02-06-2014 05:10 AM in reply to: Habib_Nespak
If all you are looking for is "want to find the difference of elevation", then all you need to do is create a "Tin Volume Surface".  A tin volume surface is the difference between two existing surfaces in Prospector. I.E., contour lines will represent the difference between surfaces at any given point.
Bill
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
