Civil 3D Forum
Proposed and Existing Elevation on a single Point
2 REPLIES 2
601 Views, 2 Replies
dears
i want to show a two elevation like ground level and proposed level at same point and want to find the difference of elevation.
please help me in this regards
Habib Ahmed
2 REPLIES 2
Joe-Bouza
Use a reference component in your label style to pick up the second surface
Joe Bouza
wfberry
If all you are looking for is "want to find the difference of elevation", then all you need to do is create a "Tin Volume Surface".  A tin volume surface is the difference between two existing surfaces in Prospector. I.E., contour lines will represent the difference between surfaces at any given point.
Bill
Rail Community
