Civil 3D Forum
Property Line in Sections
4 REPLIES 4
1305 Views, 4 Replies
Has anyone figured out a good method to show a
property line in section views similar to the way we did it in Land?  I
just want to see a vertical line in the section view with a label that says PL
or something.
Matt Kolberg
4 REPLIES 4
Matt:
If there is an alignment defined corresponding to the property line, you can
use the profile grade points feature within each of the sections properties.
You can even create a marker style that shows PL.
The only problem is that I think you have to do this for each of the
sections individually.
Hopefully, someone will give you a better answer.
Sincerely,
Drew Burgasser
CAD Masters, Inc.
"Matt Kolberg" wrote in message
news:4846175@discussion.autodesk.com...
Has anyone figured out a good method to show a property line in section
views similar to the way we did it in Land? I just want to see a vertical
line in the section view with a label that says PL or something.
Matt Kolberg
Thanks Drew. That will do the trick. I certainly hope there is, or will
be, a way to get those to show in my section views all at once instead of
one at a time. Cool, but very time consuming with 100+ sections.
Matt Kolberg
"Drew Burgasser" wrote in message
news:4846306@discussion.autodesk.com...
Matt:
Sincerely,
Drew Burgasser
CAD Masters, Inc.
Matt Kolberg
The easy way to get your pline to show in the section view... or at least I
think it is easy. Create a offset assembly left and right of your current
assemby and have it transition to a alignment that follows your pline. For
the offset assemblies I just use a vertical link that projects to the
current surface. Property lines show up for the whole corridor no problem.
Hope this helps.
Robert Howell
RD Lewis and Associates
news:4846585@discussion.autodesk.com...
Matt Kolberg
Matt:
Sincerely,
Drew Burgasser
CAD Masters, Inc.
Matt Kolberg
That sounds like a good idea. I tried that already, but it didn't work. I
tried in in 2005, however. I'll give it another shot. Thanks for the
suggestion.
Matt Kolberg
"Landman" wrote in message
news:4859163@discussion.autodesk.com...
Hope this helps.
Robert Howell
Matt Kolberg
Matt:
Sincerely,
Drew Burgasser
CAD Masters, Inc.
Matt Kolberg
Rail Community
