Civil 3D Forum
Properties dialog box
13 REPLIES 13
Message 1 of 14
536 Views, 13 Replies
I just installed 2015. The properties dialog box will not display. It was displaying or but no longer is. This happened before on an older version and I don't remember how I fixed it. I do not want to have to reinstall. Can someone assist?
13 REPLIES 13
Message 2 of 14
doni49
Try CMDDIA.  Set it to 1 if it's not already.  I don't remember off hand if the properties dialog is one of the dialogs controlled by this var but it's worth trying.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 3 of 14
wfberry
If you type PROPERTIES in the command line, what happens?
Bill
Message 4 of 14
doni49
in reply to: wfberry
Bill
Sometimes it's the simplest things.  🙂
I guess I assumed OP had already tried that and it wasn't opening.
Don Ireland
Message 5 of 14
Nothing happens.
Scott Brown, PE
4D Site Solutions, Inc
Sent from my Verizon smartphone
Message 6 of 14
in reply to: doni49
Correct. Nothing happens at the command line.
Scott Brown, PE
Message 7 of 14
doni49
Check to see if it's docked & minimized.
Don Ireland
Message 8 of 14
in reply to: doni49
No. I have checked all of that.
Scott Brown, PE
Message 9 of 14
doni49
Minimize everything except acad, take a screenshot of your entire desktop and post that.
Actually: do one before you type properties and another after.
Don Ireland
Message 10 of 14
in reply to: doni49
Already set to 1
Scott Brown, PE
Message 11 of 14
wfberry
You didn't perhaps have a second monitor at one time and now it is gone.  In the past this was a problem because the box was on a "phantom" monitor.
Bill
Message 12 of 14
I have 3 monitors and they are still there.
Scott Brown, PE
Message 13 of 14
doni49
in reply to: doni49
I'd still like to see the screenshots.  I don't know how many times I've had a co-worker tell me that they couldn't get a dialog box or toolbar to show up only to find out that I was able to see a little something that indicated what the issue was.
Don Ireland
Message 14 of 14
CADvisers
Temporarily change you monitor configuration to have the one on the right the "left side" and vise versa for the left.  The properties dialog should appear in one of them.  Drag it to the main monitor and change your monitor config back to the way you want it.
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
Rail Community
