Civil 3D Forum
Properties Palette
19 REPLIES 19
Message 1 of 20
jmatte2004
1133 Views, 19 Replies
Properties Palette
the properties palette started only showing the current properites for the drawing and not the properties  of the entity selected. what causes this i am using autocad civil 3d 2013.
jason
19 REPLIES 19
Message 2 of 20
tcorey
in reply to: jmatte2004
Set PICKFIRST to 1.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 20
jmatte2004
checked that it is set to 1 i changed it to 0 and then back to 1 and it still the same not working. thanks anymore ideas of what it could be.
jason
Message 4 of 20
tcorey
Yeah, sorry, Pickfirst doesn't seem to affect this. Can you post your drawing?
Tim Corey
Redding, CA
Message 5 of 20
troma
Quick thought: do you have two versions of C3D running? I've been confused before by looking at the properties palette of one, when I was running the other. Typically this can happen while we're updating from one version to another.
(Sorry, but sometimes it pays to ask the stupid questions!)
Mark Green
Working on Civil 3D in Canada
Message 6 of 20
jmatte2004
in reply to: tcorey
yeah this is the drawing i am working with but it happens with any drawing.
jason
Message 7 of 20
jmatte2004
in reply to: troma
no i only have one version and only have one instance running also.
Message 8 of 20
troma
Have you tried:?
Close the palette & reopen it (Ctrl + 1)
Close the program & restart
Shut down the computer & restart
Mark Green
Message 9 of 20
tcorey
It's a longshot, but you don't happen to have PROPOBJLIMIT set to 0?
Tim Corey
Redding, CA
Message 10 of 20
jmatte2004
in reply to: troma
yeap did all that too!!!
Message 11 of 20
jmatte2004
in reply to: tcorey
no its set to 25000
Message 12 of 20
tcorey
Repair install.
Tim Corey
Redding, CA
Message 13 of 20
jmatte2004
in reply to: tcorey
yeah i figured i was hoping not to do that.
Message 14 of 20
wfberry
It takes less than 10 minutes.
Bill
Message 15 of 20
jmatte2004
the simple reinstall didn't work. trying to do a repair.
Message 16 of 20
Jay_B
Have you tried  Resetting AutoCAD Civil 3D 2013 settings ?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 17 of 20
jmatte2004
in reply to: Jay_B
never recommend that to anyone else ever jay. that doesn't work and in fact it makes things worse not only does it not fix the problem now you have to re-configure your work enviroment also.
Message 18 of 20
Jay_B
Sorry to hear that didn't help either, part of the instructions cover backing up any customized files prior to resetting.
Normally not the first thing I'd recommend but you'd already tried reinstall and repair which didn't seem to fix the issue either.
We've used the reset user settings a couple of times with success fixing various machine specific issues.
Have you also tried logging in as a new Windows User account to see if that makes any difference?
C3D 2018.1
C3D 2016 SP4
Message 19 of 20
jmatte2004
haven't tried that but i think if i do a uninstall and a total re-install that would fix my problem
jason
Message 20 of 20
tmullins
You don't have ProjectWise installed do you?
http://beingcivil.typepad.com/my_weblog/2013/01/object-properties-missing-after-projectwise-is-insta...
This happened to a couple of our users and the link took care of it.
Rail Community
