AutoCAD Civil 3D General
Active Contributor
Message 1 of 1 (235 Views)
Projected COGO points grips missing on plan
235 Views, 0 Replies
09-09-2012 04:47 PM
Hi there,
I am having a hard time with projected COGO points. I need to insert COGO points along the geometry points of an alignment, then project them on its relevant profile view. That works fine. The issue comes if I try to drag the point label on plan view. The grip is gone. If I remove the point from the projection, the grip is back. I do need to drag the labels as I need to display their leaders from their dragged state component. I don't want to remove the projection of all points, since I have almost a 100, and then project them again. Any idea how to get the grip back?
I have attached a couple of images illustrate.
Thanks for your help.
Cheers
Javier
Civil 3D 2011, Windows XP 64b
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
