I currently have the 2013 Infrastructure Design Suite loaded. Since I heard that Project Base Jump was extended to early next year I thought I would download and give it a try. Here is my dilema. When I go into FDO, I see my new Connection "Add Basemap Services Connection". I click on this and hit Connect, and as expected the three entries come up. Aerials with Labels, Aerial, and Road. Here is where I have my problem. I check one or all three, it really doesn't matter, then I click on add to Map. Once I do that everything that I checked becomes un checked? It appears that it is not sticking.
Has anyone elese encountered this with Project Base Jump in C3D? Here is th funny thing about this, is since I have Map 3D 2013 with IDS, Project Base Jump is working fine in there but not in C3D.
Thanks in advance for any help!
K
What geodesic datum did you use in model space? It may be for cause of geodesic datum.
I have no Civil to replicate your issue, but perhaps you cannot "add to Map" more than once, that's why it becomes unchecked...
