Civil 3d 2012
When I try to use grips to adjust a leader, program locks up (Not Responding)
I close and look for a solution and this is the problem details that I am given:
Description:
A problem caused this program to stop interacting with Windows.
Problem signature:
Problem Event Name: AppHangB1
Application Name: acad.exe
Application Version: 24.2.51.0
Application Timestamp: 4d4b756f
Hang Signature: 58c2
Hang Type: 0
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 1033
Additional Hang Signature 1: 58c223b5445486c28406f71c7d0cd921
Additional Hang Signature 2: ad97
Additional Hang Signature 3: ad97c44ecdcf8a6ea3d105cf34f35df9
Additional Hang Signature 4: 58c2
Additional Hang Signature 5: 58c223b5445486c28406f71c7d0cd921
Additional Hang Signature 6: ad97
Additional Hang Signature 7: ad97c44ecdcf8a6ea3d105cf34f35df9
Anyone got any ideas. I can't get past two or three commands.
For some reason my AutoCad Civil 3D program keeps locking up when it can't seem to locate a font file. I don't understand since it is in my fonts and I don't understand why it won't allow me to select another font shape in order to access my drawing. I have to completely close out of the program, below is the message I get.
Loading AEC Architectural Base...
Loading AEC Structural Base...
Loading AEC Area Base...
Loading AEC Dimensions Base...
Loading AEC Schedule...
Loading AECC Hydrology...
Opening an AutoCAD 2010 format file
"dgnlstyle-tsaec.shx": Can't find file in search path:
G:\2011\11-317\Survey\Survey Working Folder\Drawings\ (current directory) C:\Users\jerryg\appdata\roaming\autodesk\c3d 2012\enu\support\
C:\program files\autodesk\autocad civil 3d 2012\support\
C:\program files\autodesk\autocad civil 3d 2012\fonts\
C:\program files\autodesk\autocad civil 3d 2012\help\
C:\program files\autodesk\autocad civil 3d 2012\express\
C:\program files\autodesk\autocad civil 3d 2012\support\color\
C:\program files\autodesk\autocad civil 3d 2012\civil\
C:\program files\autodesk\autocad civil 3d 2012\bin\fdo\
C:\programdata\autodesk\c3d 2012\enu\data\symbols\mvblocks\
C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\drv\
SOMEONE PLEASE HELP!!!!!!!!!!!!!!!!!!
...can you give us the position of "my fonts"? Best would be a screenshot of Windows-Explorer where we can see the full directory path plus the shx-file.
- alfred -
The font file is in the directory in which it is trying to find it, sorry I didn't mean that it was in a folder called "my fonts". The fonts are in location as follows, Local Disk C/Program Files/Autodesk/AutoCAD Civil 3D 2012/Fonts.
Well, don't waste your time, make a copy of the classic SIMPLEX.SHX in C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\Fonts and rename it as dgnlstyle-tsaec.shx
Is this a standard font for the company you work for? If it is you need to add the font to your support files. If not, based on the name, it looks like it is a compiled shape file for use in linetypes, most likely coming from a consultant, etc. Simply creating a font named the same thing will still give you errors. You will need to dig into the origin of your files and ask whoever sent them to you to provide their custom shp file. You might already have it if they were nice in the first place and etransmitted their files with everything included. Your other option is to change the linetypes in your drawings to match AutoCAD or your company's standard linetypes.
BTW this was a new topic, and you should have started a new discussion for your problem.
~ Mary
@jwambsgans,
Can you reproduce the lock-up problem in multiple drawings, or only the one drawing that you're working in? If you can reproduce with a sample drawing and provide the steps here, that would be good. If you can reproduce only in your drawing, can you post it here, or provide it to Autodesk Subscription Support with details? Thanks.
See my post about grip editing freezing my machine. I have experienced issueds with leaders in the past, as well as with hatches.
Hatches used to kill me and my session - hung machine with no coming back if I grabbed one. This was traced to a corrupted profile (OPTIONS).
Can you duplicate what is happening to me when I freeze the machine by grabbing AEC objects like COGO points and feature lines? When it occurs (freezes) open a WIndows Explorer window, click in the pane, do nothing but immediately go back into C3D. DOes the program then respond? Sometimes I get it back by hovering over the task bar icon when I have miltiple drawings open and clicking on a different drawing, then doing the same thing and clicking the drawing that I was working in when it froze.
release 2012 here btw.
Hi guys....I have an acer aspire 4gb RA, with nvidia 210 card.....I was told that would be good enough for autocad civil 3d.....WELL, I now cannot open a drawing of a road design as it is not responding...I know its working....but surely my system can handle it?
@jwambsgans
Do you have dynamic input on?
I have found in the past that dynamic input has a huge impact on grip operation in civil 3d.
Another thing to try is to turn off any layers of alignments and surfaces if the tooltips are set to show.
neilyj (No connection with Autodesk other than using the products in the real world)
