AutoCAD Civil 3D General
jabei
Message 1 of 3 (150 Views)
Profiles
150 Views, 2 Replies
11-25-2011 01:29 PM
Is there a way I can take my finished ground profile in my profile view and get Civil 3d 2011 to label the pvi's in the plan view?
Distinguished Mentor
Message 2 of 3 (136 Views)
Re: Profiles
11-25-2011 10:26 PM in reply to: jabei
Yes, check out the labels for the alignment. There is a label type to do what you are looking for.
Christopher
http://blog.civil3dreminders.com/
Distinguished Contributor
sadekcivil
Message 3 of 3 (135 Views)
Re: Profiles
11-25-2011 10:39 PM in reply to: jabei
Yes, absolutely you can do that.
1- Go to alignment labels.
2- Go to Profile geometry points and select point label style to code and stations and press the down arrow to select an action and press the bottom content as shown below
3-Select the properties (PVI Elevation) and then press the Right arrow bottom to add this content to your label style and eventually you can erase other content or leve it as you want to display.
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
