Civil 3D Forum
Profiles won't check in
6 REPLIES 6
176 Views, 6 Replies
I have an FG and EG program for each alignment. The alignments and profiles are all part of the vaulted project. On several alignments, the FG refuses to make itself part of the project. We go to check the drawing in, select the alignment and each of the profiles we want checked in and check it in. It looks like everything has worked, but then if you look in the project, the alignment and EG are there... but no FG.
Any ideas?
6 REPLIES 6
Just a thought...have you tried to delete the offending FG's, redraw them,
and then try to check them in again?
Matt
Are you creating the FG in the same drawing as the original alignment? Just
checking...
James Wedding, P.E.
Engineered Efficiency, Inc.
Civil 3D 2007
XP Tablet, SP2, 2GHz, 2G
www.eng-eff.com
www.civil3d.com
deleting them isn't really an option if it can be avoided since they all have extensive corridors built based on them.
Yes they are done in the same drawing as the original.
Could there be a naming conflict?
Fred Mitchell
APAI
I haven't tried renaming then yet but I will give it a whirl. Generally when there are naming conflicts I get a popup telling me and the checkin process just stops. Maybe that isn't how it works for profiles?
Rail Community
