AutoCAD Civil 3D General
Message 1 of 24 (965 Views)
Profiles Not Synchronizing upon Open
965 Views, 23 Replies
10-19-2012 09:44 AM
I have found recently that surfaces that are sampled in profile views are not synchronized when the drawing is opened. This is incredibly frustrating when I'm just opening a file to plot a new copy. If I forget to resynchronize the drawing, the sampled profiles will not plot.
Is there a system variable I might try to toggle?
Clayton Farrow
Civil 3D 2014
Windows 7 Professional
Intel Xeon E31270 @ 3.4 GHz
8 GB, 64-bit
*Expert Elite*
Message 2 of 24 (901 Views)
Re: Profiles Not Synchronizing upon Open
11-01-2012 08:35 AM in reply to: cfarrow
I've never had a problem with this.
Just to be clear, are you shortcutting a surface and sampling a profile from it in the current drawing, or are you sampling it elsewhere and shortcutting the profile in along with the alignment?
Are your alignments shortcut in, or local?
I've used both setups, no problem (AFAIK!!)
Credit where credit is due! Give kudos or accept as solution whenever you can.
*Expert Elite*
Jeff_M
Message 3 of 24 (898 Views)
11-01-2012 08:44 AM in reply to: cfarrow
Do you, by chance, have Service Pack 2.1 installed?
Message 4 of 24 (893 Views)
11-01-2012 09:52 AM in reply to: troma
In the situation that I was having issues with, I was shortcutting a surface and sampling the surface in the file. Alignments were also shorcut.
Clayton Farrow
Civil 3D 2014
8 GB, 64-bit
Message 5 of 24 (892 Views)
11-01-2012 09:53 AM in reply to: Jeff_M
Yes, I do believe I have 2.1 installed.
Clayton Farrow
Civil 3D 2014
8 GB, 64-bit
*Expert Elite*
Jeff_M
Message 6 of 24 (858 Views)
11-11-2012 08:49 AM in reply to: cfarrow
I have had similar issues with SP2.1 installed. I opened a support case with Autodesk support which is still unresolved. I've just returned from a 3 week vacation so hope to get to the bottom of this soon. If you choose to also log a support case, please request that Seth Hall handle it and mention that this appears to be the same issue as CaseNo:07674324. In my next email exchange with him, I will mention this thread so he can see others are experiencing this.
Active Contributor
Message 7 of 24 (792 Views)
12-18-2012 11:22 AM in reply to: Jeff_M
I'm having the same problems with surfaces and alignments.  Every time I open the drawing I have to synchronize the surfaces and alignments.....which is really annoying with 3 surfaces and over 20 alignments.
*Expert Elite*
Jeff_M
Message 8 of 24 (789 Views)
12-18-2012 11:30 AM in reply to: jonebease
Please submit a support request through the Subscription Center or, if not on subscription, HERE. Request that Seth Hall be informed.
Active Contributor
Message 9 of 24 (746 Views)
01-22-2013 01:26 PM in reply to: Jeff_M
I did that without any response and I'm still having the same issues with my drawings.
Alignments and surfaces are referenced in multiple drawings and work properly.  However I have one drawing where I must sync each and every alignment every time I open the drawing and relabel each alignment every time.
Now the one of the surfaces will not show up even after syncronizing.
Active Contributor
tspoon005
Message 10 of 24 (673 Views)
04-15-2013 05:13 AM in reply to: cfarrow
I have the same problem and reported the bug as instructed by Jeff.  Has anybody experienced some kind of resolution for this problem, or are we all still manually sync-ing?
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
