I have an alignment and profile created for a mteric project I am working on. The alignment is set up so it starts at 10+00 but when the profile is created the profile horiz axis starts at 100+00. Anyone have a clue what might cause this?
Is this in the profile view? If so, check the Profile View style settings, and see if it is in there.
yes in profile, everything is set to 10+00 but its labelling it as 100+00
It could be the band style or the profile view axis style. Somewhere in there you have a text component set to have 100 before the 00. It will be one of the two places I suggested. We could tell you for sure if the DWG was attached.
well if anyone could take a look at the drawing and see if you see what the problem would be I would appreciate it. I cant figure it out. Thanks!
Your original post was:
"The alignment is set up so it starts at 10+00 but when the profile is created the profile horiz axis starts at 100+00. Anyone have a clue what might cause this?
This was not the case, the original Aligmnent station was 10+000 which for all practical purposes is 100+00 (displayed incorrectly).
Bill
