Hi everyone, I'm working with plan production sheets and having some trouble. My vertical exaggeration makes me want to split the profile, but when I do it, they get glued together. My left vertical grid numeration stays on the middle of the grid and I get a lot of information overlapped. What I need is to put some gap between these, or split'em. Other issue is that the axis offset of my Profile Style isn't being applied, as well as other configs.
What should I do? Thanks.
Solved by el.Topo. Go to Solution.
hi, I usually have a profile view style which I name "split" and has these unwanted labels turned off, and apply it in the splitted sections of the profile view
I do this similar to vk_topo, in this example I create 2 additional profile Styles and apply them left and Right.
The heavy vertical split line was drawn in manually.
