I just looked at your image again and noticed you don't use a band anyway,
so disregard the portion about the bands.
"Jeff Mishler" wrote in message
news:6389481@discussion.autodesk.com...
> OK, yes you can do this....
> Turn OFF the display of the Major station labels for the PV. Set the Band
> Major station labels to NOT label the station, just the elevation data.
> Create a Profile Label Style that labels Major Stations, set the anchor
> point to be Anchor Station Extension. When adding the Profile Labels to
> the
> profile, set the Dim Anchor Point to the Graph View Bottom.
> Play around with that and you should get what you want.
> HTH,
> Jeff
> "dperde" wrote in message news:6389454@discussion.autodesk.com...
>> No, that's not what I'm looking for. If I change the station range in the
>> station tab of profile view properties the grid will follow the specified
>> range. Like I said, I need to show a grid from -3+00 to 6+00 station
>> range, but I want to label the major stations only from 0+00 to
>> 3+00. I don't see to get an option on the profile view properties, and
>> there isn't one in the band sets either. I thought someone knows
>> something
>> that I'm missing?
